QuangBang Posted February 19, 2006 Report Share Posted February 19, 2006 Can any of you noticec a difference between recording in Hi-SP and Hi-LP? Quote Link to comment Share on other sites More sharing options...
bobt Posted February 19, 2006 Report Share Posted February 19, 2006 easiest way is to make a recording of the same song in both modes ( and all the others if you have SS 3.4 and a HI-MD) and listen with good heapdhones. Due to the nature of the two, it will be impossible for Hi LP to sound as good, but for non critical recorsings, or playback in a noisy environment it may suffice. Again, your ears are the best judge, try it yourself.BTW welcome to the comminity, what do you have??Bob Quote Link to comment Share on other sites More sharing options...
QuangBang Posted February 19, 2006 Author Report Share Posted February 19, 2006 Yeah I think i'l try that, i will use it mostly on the bus so maybe LP would be ok for me. Got a MZ-RH10, missed MD so much, use to have a MZ-N10. Quote Link to comment Share on other sites More sharing options...
Qwakrz Posted February 19, 2006 Report Share Posted February 19, 2006 I have a standard MD disc here full of Hi-LP recordings that I take to uni with me, when traveling on the bus I cant tell the difference between Hi-LP and Hi-SP due to the background noise. When I am at home though I swap the my Hi-SP discs as I can hear the loss in quality you get with Hi-LP because its a quiet environment. Quote Link to comment Share on other sites More sharing options...
pauljones52 Posted February 19, 2006 Report Share Posted February 19, 2006 For me HI-LP is a little too lossy for headphone listening, LP2 is fine in noisy environments Quote Link to comment Share on other sites More sharing options...
