ATRAC3plus 352/192 recording times
WaywardTraveller
Hello,
After trying out the new ATRAC3plus bitrates, calculating for my own use the amount of music that will fit on different length MDs with these compression rates, I thought these figures might be of use to those of us who are tinkering with the balance between quality/disc space.
the figures below I produced by:
1. Taking the amount, in MB, for an 80min disc for each compression rate as per SS (using the Import CD dialog box)
2. dividing the MB by the no. of min to get a base figure of MB/min. of recording time
3. dividing the disc space in MB by the base unit to get a rough figure of the total recording time in min.
4. hacking a couple of minutes off to err on the side of caution
Based on my experiences with close shaves vis-a-vis recording space, I think it might even be better to cut a couple more minutes off to make sure you can plan accordingly. Anyways, my figures are below; I majored in lit. and not math, so corrections are welcome!
ATRAC3plus 352kbps:
1GB: 6hrs. 22min
80min: 1hr. 52min
74min: 1hr. 45min
ATRAC3plus 192kbps:
1GB: 11hrs. 40min.
80min: 3hrs. 30min.
74min: 3hrs. 13min.
Hope this helps someone.
peace
WaywardTraveller
Edited by WaywardTraveller
