agh, software probs
hitman_leon
Just got a mzrh910 and spent all day trying to get the software to work right. Used all the advice on th forum and got nowhere. When I start up the software its taking 100% cpu time and you can't see what you are doing. The menu items at the top of the window flash like its a graphical glitch. With sheer luck I have managed to transfer some files to the player with the software but its like pulling teeth. The program just locks up and if you try and scroll through files it dose not have any effect for about a minute then it jumps through htme and locks up again. Its ok to use windows to drop files in as storage on the disk but the software is pants.
newest sonicstage software for md
winxp fully up to date
xp2600 and 1 gig ddr400
anti virus off
used usb 1 and 2 ports
system is tip top no problems except with sonic stage.
