Non rechargeable battery
leoz
There are also the 1st generation units. NH600(D), NH700 and NHF800 run directly with AA's, while you can attach a case to the NH900. Only the NH1 needs its own proprietary li-ion battery, which i guess will be hard to find in 10 years.
By the way, there are also inexpensive high capacity rechargeable NiMH AA's, which will last even longer than most Alkalines. Do your environment a favor and use rechargeable batteries.
Edited by greenmachine
Thanks a lot! I intend to do that, but I need the md for my job, and sometimes there is no time to charge the battery. Just one final question, this hi-mds support Sonicstage software? Because I need to transfer from the md to the pc in high speed.
Regards and thanks again
