How do you record without the silences making a new track?
AliceWonder
There is no real way to disable this "feature" when recording with line-in.
It is possible to "disable" the feature by injecting background noise of some kind that shows up on the record metres at at least the bottom segment, but this method is less than useful in terms of its effects on fidelity and dynamic range.
Basically: combine the tracks on the unit, with SS after uploading, or with editing software after exporting to WAV.
The "Combine" function in SonicStage does this pretty well and painlessly. Just make sure you highlight the tracks you want to combine in order--from beginning to end or top to bottom, not bottom to top--because it combines them in the order you highlight them. For ultra safety, convert the original separate tracks to .wav first and save them somewhere, but you probably won't need them.
