CONNECT Skins
Chris J
Hi all,
After looking through the CONNECT directory I found 2 images that control the interface in CONNECT. I was curious to see if I could recolour these in Adobe Photoshop so I could change the purple colour, and it worked.
I was very surprised to see this; most interfaces are hard coded into the programs but CONNECT grabs the interface from a standard PNG image! Which makes it stupidly easy to change the look of the program. It is intirely possible to change all the buttons, and if I wanted to, it could put "iTunes" (for example) at the top of the window where it says CONNECT. :lol:
Here they are (you'd have to be brave to use a couple of these colours admittedly LOL):
Green
Preview | Download
Blue
Preview | Download
Gold/Green
Preview | Download
Rose
Preview | Download
Red
Preview | Download
Yellow
Preview | Download
Orange
Preview | Download
Silver
Preview | Download
INSTALLATION:
  1. Un-zip the file
  2. Go to: 'C:\Program Files\Sony\CONNECT Player\Scripts'
  3. [iMPORTANT] Find 'large-background.jpg' and 'window-background.png' and MOVE THEM or BACK THEM UP. These are the files you will be replacing and contain the original purple skin. Should you wish to revert back to the original skin, you will have kept these files to do so. Without them you cannot get the original purple skin back unless you re-install CONNECT or get a nice friend to send the original files to you =)
  4. Now copy the files you unzipped earlier and paste them into The Sony\CONNECT Player\Scripts folder (which should still be open unless you just closed it)
  5. DONE!
You could also mix-and-match different colours if you wanted.
On that note, would anyone be so kind to send me the original 'large-background.jpg' file? :lol: I overwrote it before thinking!
I hope someone finds these useful / enjoys them - they're just a bit of fun. Feel free to make some yourself and post them here to share! As I said, they are stupidly easy to make as everything is contained within 1 PNG file except the background texture.
-Chris
Edited by Chris J
We can host these for you, if you want. Excellent work.
Feel free :D If you host them, it'd be a good idea to host the originals too (which I only have 1 of as I said) if people overwrite the original purple.
Glad you like them :P (Although I can't see anyone using the yellow, orange or red haha).
