Converting MPEG-4 files to SonicStage
ironman2632
I have SonicStage v3.3 and I purchased a music file from iTunes that I would like to transfer to NetMD. This file is MPEG-4 audio. Anyone know what I need to do? Thanks.
Get dbpoweramp from Downloads or from
http://www.dbpoweramp.com/
Make sure you install the mp4 codec from its Codec Central tab.
Convert it to .mp3 at a high bitrate (>192), or .wav if you've got lots of hard drive space. Let SonicStage convert that to ATRAC.
U can also choose winamp, wich i think has mp4 codec installed as default, then you can choose the diskwriter output plugin (also installed by default) and i would recommend to create a .wav file, since no recompression is made this way. Dbpoweramp is pretty much the same, but i suggest just a wav file, instead of mp3 :)
