Importing ATRAC file from a Sony Minidisc player
simonshields
Hi,
I have a live recording of my sons band on minidisc.
I want to try and import this back onto my pc so that I can
convert the ATRAC to MP3 or whatever to put on CD.
Unfortunately I am falling at the first hurdle, when I try to
retrieve the file from my minidisc player using Sony sonic stage
I get the error "detected errors whist transferring check in failed"
Am I doing something wrong in the transfer, I am have tried using
the import arrows, I have tried dragging and dropping but aways get the same
result above. Basically am I trying to do something that isnt possible
Any help would be much appreciated and would get my son (and his bandmates)
off my back
Thanks in advance
P.s Minidisc is a sony Net MD MZ-N910
Your 1 and only problem is the MD must be a Hi-MD and you are attempting this with a Net MD which will not work using Sonicstage. Try using Marcnet's HiMD Renderer program which has a tool to help with the realtime analog copying you will have to do to get it on PC.
Or buy a Hi-MD and re-record the tunes in HiMD format, then you will have no problems (with uploading :ok: )
