Old discs of 80 reformatted to HiMD...
Well i formatted an old 80' disc to the new HiMD format, so it says now i have something like 288MB...I started copying songs...I fill it a little bit, that's, i still have another 180MB free. I try to copy 2 more cds at 64kbps (it should be room for free, for sure!) but it says some of the songs won't be copied because there is no free space (not any other problem with rights, at this point, those are wav files!), just copies 3 songs, that makes around 15mins of music@64kbps...and then says that i've just 640KB left on the disc! What's going on here??
perhaps they were not converted? see if you have 'transfer as is' set or any other settings wrong in the transfer settings menu (under tools) and go into the advanced as well as there are options that could cause such
