sebhan Posted March 30, 2006 Report Share Posted March 30, 2006 Hi guys,I recently got a nh1 but it seems to be missing the usb cable (which sucks since the only reason I wanted a hi-md was because of the usb functionality, was using the old old sharp 821 before this). So the question is can I buy the cable somewhere separately? and also are all the sony hi-md recorder usb cables the same?thanx in advance ! Quote Link to comment Share on other sites More sharing options...
Mr_Bass_Man Posted March 30, 2006 Report Share Posted March 30, 2006 Sony HiMDs use different USB cables, the one for the NH1 is non-standard. It looks rather similar to the one used in the N10, but I haven't dared try them in the "wrong" machines as they are not absolutely identical, and the pins look like they won't take a lot of abuse ...Most machines seem to use the "mini B" connection, which is easily obtainable, but alas not the NH1.They may be available separately from Sony, presumably at a price, or maybe even on EBay (I got a spare one for my N10 that way), though I don't recall seeing one.Best of luck! Quote Link to comment Share on other sites More sharing options...
sebhan Posted March 30, 2006 Author Report Share Posted March 30, 2006 ahh thank you so much for your replyguess I'm kinda stuck then, checked ebay, sony canada/us/japan but no luck...having said that is there anyone out there with a spare cable for sale/trade/give/barter ^^ Quote Link to comment Share on other sites More sharing options...
eriktous Posted March 30, 2006 Report Share Posted March 30, 2006 I just did a search on eBay for nh1 and a couple of those cables came up.Have a look at these items. Two from China and one from Germany (which only ships within Europe, so depends on where you are).587425798597023695937603732010 Quote Link to comment Share on other sites More sharing options...
sebhan Posted March 30, 2006 Author Report Share Posted March 30, 2006 tyvm ^^ guess i should have searched better hehe, hope they arrive soon can't wait till i test it out Quote Link to comment Share on other sites More sharing options...
Smemo Posted March 31, 2006 Report Share Posted March 31, 2006 I bougth one from ebay some days ago.The item id is 9702369593He shipped it from China to Italy in 15 days.The quality is great.Ciao, Smemo Quote Link to comment Share on other sites More sharing options...
1kyle Posted March 31, 2006 Report Share Posted March 31, 2006 Sony HiMDs use different USB cables, the one for the NH1 is non-standard. It looks rather similar to the one used in the N10, but I haven't dared try them in the "wrong" machines as they are not absolutely identical, and the pins look like they won't take a lot of abuse ...Most machines seem to use the "mini B" connection, which is easily obtainable, but alas not the NH1.They may be available separately from Sony, presumably at a price, or maybe even on EBay (I got a spare one for my N10 that way), though I don't recall seeing one.Best of luck!It's the same as the N10.Cheers-K Quote Link to comment Share on other sites More sharing options...
sebhan Posted March 31, 2006 Author Report Share Posted March 31, 2006 life would be easier if everyone would use the same cable format, 15 days can't wait Quote Link to comment Share on other sites More sharing options...
Mr_Bass_Man Posted March 31, 2006 Report Share Posted March 31, 2006 (edited) It's the same as the N10.Cheers-KThanks Kyle, I'll give it a try . . .. . . Much Later . . .Yep, I can confirm that the N10 USB cable works fine with the NH1 Thanks again. Jimbo !! Edited April 5, 2006 by Mr_Bass_Man Quote Link to comment Share on other sites More sharing options...
