Question about SonicStage 3.3 ATRAC3plus bit rates
ZeroRing7_
Welcome to ATRACLife!
Among the new ATRAC3plus bit rates (320kbps, 192kbps, 160kbps, 128kbps, and 96kbps) offered with SonicStage 3.2, your unit can only utilize bit rate 192kbps. If capacity is not an issue, I would advise you to utilize 256kbps. Otherwise, 192kbps should be just fine if you need to conserve space on your unit.
Edit: forgot to add 352kbps.
Highest Bit rate supported by NW-HD3 is Atrac3 Plus 352kpbs ..which has been added in the new SonicStage ver3.3
How to Convert Cd into Atrac3 plus 352kpbs
1.)Import Audio CD tracks in Wav format
2.)Now In "MY LIBRARY" of Sonic STAGE VER3.3,Click on transfer mode setting(post-2915-1119327954_thumb.jpg).
3.)Click on "Specified Bit rate tranfer mode "& set the bit rate to Atrac3 Plus352kpbs
4.) Transfer your Wav files to your network walkman .Now Wav files will be converted to 352kpbs ..Atrac3 plus 352kpbs files will be transferred to your Network Walkman
Will playback still be gapless? I assume not...
thanks for the response guys.... just wondering why 192/352kbps is supported by not the others... if the NW-HD3/5 does not support the newer bitrates(i.e 192/352) natively, it doesn't makes sense why 128/160kbps won't work.... :unsure:
New A-series support all the Atrac Bitrates(every that you see in SSver3.3).Except that it also doesn`t supprt Atrac3 Lossless & I also don`t understand that only two newer bitrates are supported but not the others(i.e 128kpbs etc).
Only reason that i found is that our Device(hd3&hd5) are not compatible with these new bitrates.
That's how!? Thank you... I was about to make a post asking that. Always so awkward, sony and their software... Hail the search :mellow:
