Volume Hack for MZ-R909
  • 8 months later...
  GregTheRotter said:
As long as the volume steadily increases as you go from 25 or 20 to 30, you are fine.
Not necessarily. The N710 volume increases all the way & it's heavily volume capped. Some later models (such as NH1) were limited by simply not allowing the volume to increase from 24-30. Two diiferent systems, of which the R909 is most likely to have the earlier as it's closer to that generation.
