Getting more out of non 1GB discs
  Skradgee said:
Welcome to the forums? You'll need a Hi-MD recorder to do this. Standard MDs can be formatted in Hi-MD mode to get more record time / storage space.
So you need the recorder to this. Does SS also opt for this possibility? When I store files on a MD via SS it is possible to use HiMD or MD format.....
Like Skradgee said, only if you have a Hi-MD recorder or downloader can you store files through SS using Hi-MD or standard MD format. If you plug a standard recorder/downloader into your computer, SS will only give you the option of NetMD (standard). Good luck!
Edited by jaylen
