Jose408MD Posted April 14, 2006 Report Share Posted April 14, 2006 (edited) Hello Im New to this but here it goes, I have an MZ-NF520D md player and i finally got it to connect to sonic stage which i have and is version 3.1 because i heard that the new ones have more bugs, well the problem is that only some tracks will transfer to the MD. Other tracks get converted and start transferring and stop at 95% and then there is a box that says, Track "here is the name of track" cannot be transferred, Any Ideas anyone? Should I upgrade my sonicstage? I also tried Simple burner which i got from this site and When it was transferring, I got a message saying that there has been a serious error restart computer and the simple burner 2. This is really annoying. Is there a certain setting I need to transfer at? Thanks! Edited April 14, 2006 by JoseG Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted April 14, 2006 Report Share Posted April 14, 2006 welcome to the forums...1.) update your SS through a fresh install of SS3.4 (see the pinned threads in the software support section)2.)please read and post according to the rules for software support (as described in the red/pinkish link on top of this page Quote Link to comment Share on other sites More sharing options...
Jose408MD Posted April 23, 2006 Author Report Share Posted April 23, 2006 welcome to the forums...1.) update your SS through a fresh install of SS3.4 (see the pinned threads in the software support section)2.)please read and post according to the rules for software support (as described in the red/pinkish link on top of this pageThanks! It works perfectly now. Some exceptions though. some won't transfer. But i worked around it by converting the format manually instead of letting sonicstage convert it while it transfers.Thanks Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted April 23, 2006 Report Share Posted April 23, 2006 glad to hear you're enjoying MD (again)... some MP3's will fight with SS as they do not have strict 16/44,1 format or their ID3 tags are not completely according to the rulesif it really doesn't work, you can always use a freeware program to convert the from MP3 tp WMA-lossless (as this keeps track info and works fine with SS) Quote Link to comment Share on other sites More sharing options...
