Can RH10 remember some settings?
Is it possible for a way to make the RH10 remember certain settings, such as, show time remaining on the display instead of time played. For example, it can remember my record settings (PCM mode, etc) but it can't remember to show time remaining once the display automatically shuts off after not using it. ANyone else run into this issue?
Yeah every unit is like that. I find it kind of annoying as well, particularly on Sony portables because the default is not track title, it's playing/elapsed track time.
I wish that they would have started "remembering" or allowing you to set the default at some point, but they never did :(
