DuStU Posted April 20, 2006 Report Share Posted April 20, 2006 I took the recording level off manual its not the mic the mic I have is the decent stereo sony mic that most people have the ECM-MS907 I put the recording level all the way up and it is still too low.....the nI read in the forum that the mic in has a pre amp and the line in doesnt .......I dont have a mic in thats just gay all I have to work with is either the headphone port or the line in how can I make the recording level decent out of this darn mini disk player (MZ-N510 Type-S) Quote Link to comment Share on other sites More sharing options...
greenmachine Posted April 20, 2006 Report Share Posted April 20, 2006 You could invest either in a external preamp or a unit with mic-in. You might be able to get unit with mic-in used for the same price or lower than an ext. preamp. An ext. preamp means additional bulk (and also needs to be powered separately). Quote Link to comment Share on other sites More sharing options...
DuStU Posted April 20, 2006 Author Report Share Posted April 20, 2006 (edited) Where can I get a good small battery powered preamp for cheap?You could invest either in a external preamp or a unit with mic-in. You might be able to get unit with mic-in used for the same price or lower than an ext. preamp. An ext. preamp means additional bulk (and also needs to be powered separately). Edited April 20, 2006 by DuStU Quote Link to comment Share on other sites More sharing options...
