ethan hunt Posted April 25, 2006 Report Share Posted April 25, 2006 (edited) Hi All,Just wondering if any one is facing the same problem and what I can do to remedy it.I have an MZ-N920 with the RM-MC35ELK remote unit.At the moment the track fwd/back/pause button behaves extremely erratically. What occurs is that when I try to switch a track it will do a completely different function. For example pressing forward (next track) will switch to the next album, or switch on one of the sound modes. The same thing happens sometime with the volume adjust - trying to notch it up a little sometimes skips the album track. I take good care of my MD player and have tried a manner of different solutions - figuring that I was pressing too hard or too soft thus somehow jamming the function. This doesn't seem to be the case. I'm wondering if there is any technical solution I can do to the remote to restore it to its former glory. (even tho the volume on the twist has always been a pain in the ass).The remote is not dirty so I'm sure its not sticking and jamming...any other insights?Oh its only been in use from 09/2004 - I have a MZ-R55 remote that still works and that is 7 years old!Thanks in-advance,Ethan Edited April 26, 2006 by ethan hunt Quote Link to comment Share on other sites More sharing options...
ethan hunt Posted April 29, 2006 Author Report Share Posted April 29, 2006 So no ones had any problems with there shuttle/remote controls.....?Not even a tech solution to the problem....? Quote Link to comment Share on other sites More sharing options...
poe Posted May 2, 2006 Report Share Posted May 2, 2006 Did you at any point try to get in the service menu and try to perform a hack? There is a setting in there that can mess up the mapping of the buttons on your remote.POE Quote Link to comment Share on other sites More sharing options...
ethan hunt Posted May 3, 2006 Author Report Share Posted May 3, 2006 Did you at any point try to get in the service menu and try to perform a hack? There is a setting in there that can mess up the mapping of the buttons on your remote.POEhey poe,thanks for the reply. No I haven't tried any hacks on this MD unit - or used the controls in my other MD (MZ-R55).I have no idea how i can rectify the problem - unless pulling it apart and cleaning it might help? Quote Link to comment Share on other sites More sharing options...
