darcman23 Posted May 2, 2006 Report Share Posted May 2, 2006 Hey there folks. I perform in my one man show and I am looking for a great minidisc player/recorder which is the most user friendly of them all. I pretty much need a unit which will allow me to use a footswitch to start it and stop it and possibly cue up to the beginning of the song on each track. I want to be able to use this on stage and I want it to work and sound as proffessionally as possible. I was thinking about the SONY MZ-B100 recorder, I was just wondering what you guys thought of it. What do you think, is it a good unit for me, does it sound good, easy to record with, cues up, and most importantly, can I use a footswitch with it to start and stop it? Thanks a lot, from a total novice, yours truly, Darcy Chubbs Quote Link to comment Share on other sites More sharing options...
rayzray Posted May 2, 2006 Report Share Posted May 2, 2006 (edited) Hey there folks. I perform in my one man show and I am looking for a great minidisc player/recorder which is the most user friendly of them all. I pretty much need a unit which will allow me to use a footswitch to start it and stop it and possibly cue up to the beginning of the song on each track. I want to be able to use this on stage and I want it to work and sound as proffessionally as possible. I was thinking about the SONY MZ-B100 recorder, I was just wondering what you guys thought of it. What do you think, is it a good unit for me, does it sound good, easy to record with, cues up, and most importantly, can I use a footswitch with it to start and stop it? Thanks a lot, from a total novice, yours truly, Darcy ChubbsWell; i was a one man band for about 25 years; sang for over 40 years; it was my "Living"; and i would NOT use this MZ-B100 if i were you; (there is NO "line out" as far as i can see)!!!!you need a line out;; don't you?as far as foot pedal; unless you have an electrician wire one up; you are out of luck IMO.if i were you; i'd look for a PRO MD Deck; i DJ'd with them and they are great.i have talked MANY local acts here; most of them one or two man acts; to use MD Decks and they love them.you may have to rely on a remote control; but there are ways to make up a foot control to press certain remote buttons.i (rayzray) wouldn't TRUST my reputation to SMALL units that look like they would fall apart at any time; especially for pro use.you are barking up the right tree; just the wrong way; and with the wrong models.there are MANY advantages of using MD's (like setting up "sets"; and medlys) i assume these are for your background music.well; i am sure the other guys/gals will advise you wisely too; but i lived your experience; and always had the best and the right equipment. Edited May 2, 2006 by rayzray Quote Link to comment Share on other sites More sharing options...
