Looking to upgrade my MD recorder
jrv2kgt-s
In the next month I am planning on upgrading my MZ-N707 to the newer Hi-MD format. Right now there are three recorders that caught my attention and those are:
Sony MZ-RH10
Sony MZ-RH910
Sony MZ-RH1 (currently unreleased to the US market)
Should I wait for the MZ-RH1 or buy the MZ-RH910/MZ-RH10 before they are no longer on the market? Any help would be greatly appreciated.
Edited by jrv2kgt-s
if you are mainly oing to record... wait for the RH1
if you mainly want a player...the RH10 offers more playback info on its screen (otherwise the RH1 is better still)
... if you can spare the cash, just wait for the RH1 (it really is the best model thus far)
Depends on your needs. I strongly recommend the rh10 for its large and clear display. It will show all track info and has a jog dial on the unit, unlike the rh1, which cannot function at all as a player. If your sole purpose is recording and no playback at all, the rh1 is better. If you want to use both playback and recording, or just playback, go for the rh10.
"unlike the rh1, which cannot function at all as a player"
Of Course the RH1 can function as a player, it is assinine to think otherwise. From what I see it should work quite well in both regards. As the unit will spend most of it's time in a pocket or pouch, the display is moot, get a good remote, and get ready to enjoy your music.
Saying that it won't function as a player is the same as saying I can get to point A in my Cherokee, but I need my Pajero to get hom.
Just doesn't work that way.
Hope my rant doesn't offend,
Get the best you can afford, and you will like it.
All the units have plusses and minuses, weigh your needs and make a choice
Bob
The RH1 can be used as a player, just that it is not the best for navigating.
I always have less than 20 tracks on any HiMD/MD (unless I do a mistake when setting recording levels) and I could perfectly live without a jog dial.
Bob
I know it is capable of playback, that is obvious. But it would be a real pain to use as a player, especially if you don't want to use or spend money on a 40elk. With a display that can't display artist/track titles and no jog dial, a disc with hundreds of tracks is really unusable. That's why I said it will not function as a player.
When you weigh its pros against its cons, the cons are miniscule compared to what the RH1 is capable of and the components it has audio-wise. Sure, the RH1 is more of a recorder's unit, but it can also be a great player whether it has a jog dial or 5-line display or not.
In fact, most of the greatest "player-only" units do not have any kind of display or jog dial on the body, relying solely on the remote for navigation. Are you now going to say that all 30+ of those player-only units are terrible players? Probably not. For a majority of the MD population, a jog dial and unit display do not make or break a unit's reputation. You'll find it quite difficult to convince owners of the EH1, DS70, E730, S77, etc, that their player is crap because it has no display, jog dial, etc.
That's different. The EH1 is made to be slim and player-only, no inputs/outputs, not even usb. I'm making these recommendations to someone that doesn't have any himd player to write himd discs. The eh1 is nice as it is super compact, super slim, and all metal. And it is SHIPPED with the 40elk, pretty much solving any display/jog dial problems. Sure the unit itself isn't really usuable, but adding stuff like a display/jog dial would ruin the point of a player unit, being a slim and compact marvel.
Edited by RobA
Actually, your recommendations, or should I say criticisms, of the RH1 are based on its ability to function as a playback-only unit, not as an overall Hi-MD unit.
If you want, you can have a look at my opinion on the RH10, RH1 and DH10P.
Thanks for the link.
I think I will wait for the RH1 to be released in the States. My main concern is weather or not Sony will release the recorder in the US market. The fact that I can upload my MDLP recordings to file via sonicstage is reason enough to pick up the unit. Sure the unit may suffer from a small display size, but I'm used to using a small display on my MZ-N707.
