astranovus Posted May 30, 2006 Report Share Posted May 30, 2006 (edited) hi this might be a stupid question,but i have installed a turtle beach audio on my laptop,i am using the spdif output stream and have connected it to my mz-rh1 via an optical cable, i have pressed pause on the digital recording facility on the rh1,now does this mean i am using the rh1 as a quality dac when i connect my headphones to the line-out via an amp?plus when i pause the digital recording, is the laser burning or in standy-byi don't want to wear the laser out unnecessarilythx for your helpcheers astranovus Edited May 30, 2006 by astranovus Quote Link to comment Share on other sites More sharing options...
dex Otaku Posted May 31, 2006 Report Share Posted May 31, 2006 now does this mean i am using the rh1 as a quality dac when i connect my headphones to the line-out via an amp?plus when i pause the digital recording, is the laser burning or in standy-byYes, you're using your RH1 as an external DAC. There ar simpler ways [that are less stressful on the equipment] to do this though. Your turtle beach sound adapter likely already has a good output on it for headphones. If it lacks the power to drive 'phones, you'd likely be better off just using an external headphone amp.The write laser + magnetic head [since both are used for writing] should be in standby mode [the unit buffers data to be written, so it doesn't have to been written as it's converted in any case], but you're still causing wear to the equipment by leaving it in pause. Quote Link to comment Share on other sites More sharing options...
