astranovus Posted May 30, 2006 Report Share Posted May 30, 2006 (edited) please look at my ph1 pici haven't got a very close seal between the lid and player, particularly where it says "display menu"is this normal, as i think it will let dust in,if no other rh1 users have the same problem, then i need to get a new unit Edited May 30, 2006 by astranovus Quote Link to comment Share on other sites More sharing options...
Orion Posted May 30, 2006 Report Share Posted May 30, 2006 astranovus said: please look at my ph1 pici haven't got a very close seal between the lid and player, particularly where it says "display menu"is this normal, as i think it will let dust in,if no other rh1 users have the same problem, then i need to get a new unitHi,I've had 2 of these players. (Still have one of them) The gap as shown in your photo is the same on both the other units. Personally, I don't worry about dust. Everytime we pop the lid to change minidiscs we let dust in anyway.Are you happy with the player/recorder? CheersOrion Quote Link to comment Share on other sites More sharing options...
pata2001 Posted May 30, 2006 Report Share Posted May 30, 2006 Dust will get in no matter what, especially for stuff that have lids (Unless you have the MZ-S1, and never open the latch forever). Even for HDD DAPs, where everything is technically sealed, you'll find dust inside it during usage. At least with MD/HiMD, I can just open the lid, spray compressed air into the opening to dust off any dust inside. You cannot do that with HDD DAPs. Quote Link to comment Share on other sites More sharing options...
lamewing Posted May 30, 2006 Report Share Posted May 30, 2006 astranovus said: please look at my ph1 pici haven't got a very close seal between the lid and player, particularly where it says "display menu"is this normal, as i think it will let dust in,if no other rh1 users have the same problem, then i need to get a new unitHey, at least you can buy one of the RH1's. They still aren't sold here in the U.S. Quote Link to comment Share on other sites More sharing options...
