HEELLP NOT recording
rick brown
I am using a mz-m10. I have only recorded 4 sessions with it using the supplied mic. I am exporting to a mac so I am recording in PCM.
Previous sessions worked great.
Now, it won't record at all. I've checked all my settings and they appear to be correct. Battery is charged, Hi-MD is displayed, little balck square is there, PCM selected.
I insert a blank disc, it displays the title screen which of course is empty.
I hold the jog dial and press the record button and all it does is display "Blank Disc" and doesn't start recording.
If I press the reocrd buttons again it displays "no track"
Same issue occurs whether I am using a Hi-MD or MD 80 disc
Any ideas????
Thanks
Rick
you could always try to remove all power sources (including batteries) for a minute, then reinserting the battery and try again (this will reset the machine)
also check whether the discs' write protection tab is on (though I doubt that)
something like that had come in mind actually... but as I only own the NH900 and RH1 which both use different rec-triggers (a slider) I was too uncertain about the RH10's procedure to say something about it :P
from now on I'll try to give all options springing to mind no matter how rediculous :lol:
