esacerdoti Posted June 25, 2006 Report Share Posted June 25, 2006 Hi! the topic title speaks for itself, i want to buy new minidisc, mostly for recording (pc connectivity needed).I found only this ones but i'm not that sure on their differences, so can anyone help me?Also if anyone knows about other models (hi-md, from sony) that can be found in USA or Argentina, please tell me.Thanks Quote Link to comment Share on other sites More sharing options...
raintheory Posted June 25, 2006 Report Share Posted June 25, 2006 (edited) The units are identical in features with one exception: The RH10 has an Organic EL Display, while the RH910 has the standard LCD.Both have Mic-in and Line/Optical-in; and can upload/download from PC. RH10 Specs: http://www.minidisc.org/part_Sony_MZ-M100+RH10.htmlRH910 Specs: http://www.minidisc.org/part_Sony_MZ-M10+RH910.html Edited June 25, 2006 by raintheory Quote Link to comment Share on other sites More sharing options...
lalomania Posted June 25, 2006 Report Share Posted June 25, 2006 Battery life is the same? Quote Link to comment Share on other sites More sharing options...
esacerdoti Posted June 26, 2006 Author Report Share Posted June 26, 2006 (edited) The Rh10: Long battery life of 32 hoursthe rh910: Long battery life of 25 hoursBesides that and the display I don't find another differences.Thanks raintheory for the reply, i think i'll buy the RH10 unless someone reccomends me different.Sorry for bad english Peace Edited June 26, 2006 by esacerdoti Quote Link to comment Share on other sites More sharing options...
raintheory Posted June 26, 2006 Report Share Posted June 26, 2006 Sorry I didn't think to compare the battery life... Go for the RH10 you won't be disappointed, the display is superb! Quote Link to comment Share on other sites More sharing options...
esacerdoti Posted June 26, 2006 Author Report Share Posted June 26, 2006 Don't worryYep I'm going for the Rh10!Thanks! Quote Link to comment Share on other sites More sharing options...
lalomania Posted June 26, 2006 Report Share Posted June 26, 2006 (edited) Any RH10 users knows what the RH10's battery life is without the AA? Edited June 26, 2006 by lalomania Quote Link to comment Share on other sites More sharing options...
