MZ-NH1
joplin
Depends on what format the recordings are in.
If the recordings are SP, LP2 or LP4--you'll see the format on the display when they play back--the only way to upload them is with the new minidisc recorder, the MZ-RH1. Otherwise, they are stuck on the disc. You can record them in realtime from the headphone jack.
http://forums.minidisc.org/index.php?showtopic=7070
If the recordings are Hi-SP, Hi-LP or PCM, you can upload them to a PC with SonicStage, available at the Sony website or from Downloads here. You have to install SonicStage and connect your NH1 with a USB cord.
http://forums.minidisc.org/index.php?showtopic=6330
Don't use the SonicStage disc that came with your unit. Use Version 3.4 (from Downloads) or 4.0 (from Sony).
Once they have been uploaded they are in SonicStage's library and you can download them back again to new MDs, convert them to .wav and burn to CDs, etc.
