panzerschreck Posted July 9, 2006 Report Share Posted July 9, 2006 Hey guys.Recently I owned the MZ-N410 minidisc player which worked GREAT. Loved it and had ZERO problems. Well, needless to say my headphones had a fit and the end piece broke off inside and it wasn't coming out. I got the headphones replaced and purchased the MZ-N420D. While this works ok sort of, the loading time for a song is anywheres between 15 seconds to almost a minute, don't know if it's defective or what. ANYWAYS. I had bought the same MZ-N410 and it was defective so I had to return it. I was currently using the Sonic Stage v3.0 I had downloaded and that worked amazing. No problems no nothing. I thought my minidisc's could have been defective before I returned the MZ-N410 and uninstalled v3.0 and installed 1.5. Well it didn't even load so that wasn't the problem. Now I got the version 2.0 with the MZ-N420D and well, it's giving me problems. I ripped songs onto my PC and tried to import them to a minidisc. It kept telling me it couldn't transfer some songs because of some error, but the funny thing is, I transferred the songs on the v3.0 before and had no problems. So I uninstalled all versions of Sonic Stage and tried reinstalling v3.0 BUT now it keeps giving me errors saying stuff is missing and it's driving me INSANE. Is there any program that does the same thing but works better than sonic stage or know how I could fix this problem.Thanks, Panzer Quote Link to comment Share on other sites More sharing options...
bobt Posted July 9, 2006 Report Share Posted July 9, 2006 Make sure you get rid of all instances of early SS and install at minimum 3.4, 4.0 probably won't have much benefit to you. Try going to hi-md as well, many more options.Good night and good luck,Bob Quote Link to comment Share on other sites More sharing options...
panzerschreck Posted July 9, 2006 Author Report Share Posted July 9, 2006 Make sure you get rid of all instances of early SS and install at minimum 3.4, 4.0 probably won't have much benefit to you. Try going to hi-md as well, many more options.Good night and good luck,BobWhere could I get those versions?Thanks, Panzer Quote Link to comment Share on other sites More sharing options...
greenmachine Posted July 9, 2006 Report Share Posted July 9, 2006 Get v4.0 here, the thread is pinned in the software subforum:http://forums.minidisc.org/index.php?showtopic=9586 Quote Link to comment Share on other sites More sharing options...
