cnpubwear Posted July 10, 2006 Report Share Posted July 10, 2006 I am using a rh910. I have only had it a couple of weeks now and am having problems. When transferring tracks using sonicstage or simple burner the track names disapear and it just says untitled. Then if I try to edit the track info manually it tells me the "Title Full".It's only doing this with one Hi-MD so far but was wondering if this was a common error. I had an NH700 for about 2 years and this never happened. Quote Link to comment Share on other sites More sharing options...
Hungerdunger Posted July 10, 2006 Report Share Posted July 10, 2006 I am using a rh910. I have only had it a couple of weeks now and am having problems. When transferring tracks using sonicstage or simple burner the track names disapear and it just says untitled. Then if I try to edit the track info manually it tells me the "Title Full".It's only doing this with one Hi-MD so far but was wondering if this was a common error. I had an NH700 for about 2 years and this never happened.According to the manual for my RH1, this message occurs when "You tried to enter more than 200 letters to label a single track; you tried to enter a total of more than approximately 55,000 letters (Hi-MD)or 1,700 letters (MD mode)for titles"While these amounts sound pretty generous, as you say it happens only with one disc, is there any chance you already have tracks on the disc which have used up your allocation? If the disc was "blank" when you started recording, have you tried formatting it? Quote Link to comment Share on other sites More sharing options...
cnpubwear Posted July 11, 2006 Author Report Share Posted July 11, 2006 that might be it, the disc is almost full now with low bit rate tracks. I'll try shortening some of the track names and see if it lets me. The disc was blank when I started recording and I'm hoping not to have to format the disc since it took forever to fill. Quote Link to comment Share on other sites More sharing options...
cnpubwear Posted July 11, 2006 Author Report Share Posted July 11, 2006 completely fixed the problem - I just need to use shorter track names and learn to read the manual. Thanks. I am very pleased I came here. Quote Link to comment Share on other sites More sharing options...
