Cant hear a thing nwa3000
Flyswatter
hi,
I own a nwa3000 since xmas, and I think it's great. But today I tried to listen to a song, and no music was produced. Very strange because the beeps, when you press play and stop, are still there. Even the ' now playing' displays im playing a song, The time bar advances etc. Does anyone know how to solve this problem?
(I've had a problem in the past. It was an heavily distorded sound in 'headphone mode' , but it sorted out by itselve because suddenly it was gone. So i dont know what it was.)
I hope you can help me, thanks!
6 answers to this question
Check Settings // Audio Output and see if "Headphone" is selected (it should be)
If you put it to Line Out it would sound really distorted through your headphones which is probably what happened before.
Don't know if this will sort your problem now but it's worth a try.
Edited by Big Bernard
Flyswatter,
Welcome to AtracLife"
Have you tried some other song with your A3000?Also Use some other headphone or Earphone & Then See.
Also I will not suggest you to Listen to songs in Line out mode for few seconds because it might damge your Headphones & As well as your EARS
