timboblane Posted August 3, 2006 Report Share Posted August 3, 2006 I have encountered a frankly bizarre and all new irritating issue in sonic stage 4. I went through the business of transfering my music to an external hard drive and using the backup tool to move my collection to another PC. this all went well, apart from multiple versions of some songs which i suspect is down to user error, but I found I couldn't edit the information of quite a few tracks in my collection. On further investigation i discovered that Sonic Stage thinks these tracks are on the E drive (which was the letter of my USB hard drive on the previous computer) instead of F, the new location for my hard drive. The tracks play and transfer alright but as i said the file info can't be altered and there seems to be no way to sort out SS's misconception. any ideas?tim Quote Link to comment Share on other sites More sharing options...
raintheory Posted August 3, 2006 Report Share Posted August 3, 2006 you could always use diskmgmt.msc to switch your drive letters around. Quote Link to comment Share on other sites More sharing options...
timboblane Posted August 3, 2006 Author Report Share Posted August 3, 2006 you could always use diskmgmt.msc to switch your drive letters around.Thanks! I'll give it a go. Quote Link to comment Share on other sites More sharing options...
raintheory Posted August 3, 2006 Report Share Posted August 3, 2006 start/run: diskmgmt.mscit's pretty straightforward, but if you're not familiar with it it may be worth googling for some simple instructions. Quote Link to comment Share on other sites More sharing options...
atrain Posted August 4, 2006 Report Share Posted August 4, 2006 you can also get into it via control panel -> administrative tools -> computer managmentif you aren't comfortable with cmd line Quote Link to comment Share on other sites More sharing options...
timboblane Posted August 4, 2006 Author Report Share Posted August 4, 2006 you can also get into it via control panel -> administrative tools -> computer managmentif you aren't comfortable with cmd linethanks fellas! Quote Link to comment Share on other sites More sharing options...
