Running Sonic Stage under Bootcamp
unusablesignal
I can't imagine why it wouldn't work with Boot Camp, since all BC does is repartition the drive to allow you to install Windows; when you boot up XP on an Intel Mac, it IS a standard PC laptop with all standard parts (including USB). It would work just like it would on any other PC laptop with Windows.
(I'd try it on the MacBook Pro sitting 5 feet to my left right now, with Bootcamp installed, but with my luck SonicStage would toast the Windows install.. ;) And it's a work machine.)
Edited by Justin42
yo, Justin42. HA! I love your balanced point of view of 'im sure it would work' and 'i wouldnt trust trying it'. Its the typical position that these tech companies put us in. Im probably gonna end up buying a Macbook just so i can buy the new minidisc machine. Not really the most cost effective way to go about things but....i guess im just a sucker for MD.
If it were a personal machine, SS would already be on it. :) Sorry for sounding kinda snarky; I just don't have the time at work to recover from a toasted XP install just in case anything does go wrong. ;)
That said, I have had 0 problems with the Macbook Pro while in Windows, it behaves exactly as a Windows machine does in everything I've tried. (USB keys, etc, especially; and it seems to use the standard Intel chipset which is really good news as that's more than likely what Sony tests the most against)
