Kherlen Posted January 17, 2009 Report Share Posted January 17, 2009 Hi!I just got S738 Walkman player and I've found some things that still mysterious for me...1. Sound quality sounds tiny little worse that A810 series Walkman2. Included noise canceling headphones sound worse that EX-082 (found in A810)3. There are tick tick sound when volume is going up and down. i.e: from 8 up to 15 and from 15 down to 8What do you think? Other than these problems i think is awesome player that could really replace iPod!! Quote Link to comment Share on other sites More sharing options...
0 tds101 Posted January 18, 2009 Report Share Posted January 18, 2009 Sounds like you got a bad player (still, check to see if the headphone cable is properly inserted into the headphone jack). Also, go to the common settings menu and do a reset and reformat of the player if the first option didn't help. If this didn't help then exchange it for another, and see if the problem resurfaces.PS: Welcome to Sony Insider!!!! Quote Link to comment Share on other sites More sharing options...
0 Kherlen Posted January 18, 2009 Author Report Share Posted January 18, 2009 Sounds like you got a bad player (still, check to see if the headphone cable is properly inserted into the headphone jack). Also, go to the common settings menu and do a reset and reformat of the player if the first option didn't help. If this didn't help then exchange it for another, and see if the problem resurfaces.PS: Welcome to Sony Insider!!!!Thanks. I tried 2 different resets and formatted the player. The problem still exists and I am not able to exchange this player with other one because i ordered this player from US.I will actually try to contact Sony about this problem...The DarkSide have you tried push the volume to 30 ? and back to 0 ? Have you heard small tick ticks? Quote Link to comment Share on other sites More sharing options...
0 basit Posted January 20, 2009 Report Share Posted January 20, 2009 Thanks. I tried 2 different resets and formatted the player. The problem still exists and I am not able to exchange this player with other one because i ordered this player from US.I will actually try to contact Sony about this problem...The DarkSide have you tried push the volume to 30 ? and back to 0 ? Have you heard small tick ticks? hm i really think that u have a bad unit.or very old firmware update it to 1.11 version i have never heard such ticks well may be u r talking abt beep sound try to turn it off may be u r taliking abt beep sound u can turn it off easily in settings>common settings>beep settings try to turn it off.see if it helps.i have nwzs-738fbnc there is no such issue Quote Link to comment Share on other sites More sharing options...
0 Kherlen Posted January 20, 2009 Author Report Share Posted January 20, 2009 hm i really think that u have a bad unit.or very old firmware update it to 1.11 version i have never heard such ticks well may be u r talking abt beep sound try to turn it off may be u r taliking abt beep sound u can turn it off easily in settings>common settings>beep settings try to turn it off.see if it helps.i have nwzs-738fbnc there is no such issueHi. I am using Walkman players and I never had this problem. I know about beep settings and that beep lot more louder than the silent tick tick... I occurs when sound goes up and down. In 15 to 30 and 30 to 15.Could you try it out for me? on your player? (Make sure you turned off beep in common settings) Quote Link to comment Share on other sites More sharing options...
0 Anthony Posted January 20, 2009 Report Share Posted January 20, 2009 You may have a faulty set of Noise Reduction headphones. Try a few things....1/ See if you have the problem with NR both on and off.2/ Try with a different set of headphones.3/ Ensure that the headphone jack on the player is free of dirt and grit( blow into it).You appear to have typical sound problems associated with faulty signal transmission. Quote Link to comment Share on other sites More sharing options...
0 basit Posted January 20, 2009 Report Share Posted January 20, 2009 You may have a faulty set of Noise Reduction headphones. Try a few things....1/ See if you have the problem with NR both on and off.2/ Try with a different set of headphones.3/ Ensure that the headphone jack on the player is free of dirt and grit( blow into it).You appear to have typical sound problems associated with faulty signal transmission.hm well try to clean the headphone plug i have tried it on my walkman there is no tick sound try nc setting of or on.well but plz clear the headphone plug iwth a soft cotton cloth such as cleaning cloth for eye glasees keep the player away from mob etc Quote Link to comment Share on other sites More sharing options...
0 basit Posted January 22, 2009 Report Share Posted January 22, 2009 well u r right but this is normal operation i guess me too hearing very silent tick tick sounds when taking volume too.10 or above i guess only when mp3 is in pause mode k.well hope so another firmware update will solve this problem.well thats no problem i have come a solution to it.jst turn off vpt its vpt(surround sound effect)and nothing else.try turning off vpt Quote Link to comment Share on other sites More sharing options...
Kherlen
Hi!
7 answers to this question
