uberin Posted January 25, 2006 Report Share Posted January 25, 2006 Hope someone can point me in the right direction....I'm trying to convert some MP3 files to 132 OMA format with Sonicstage 3.3The problem is that all of the MP3 files (320kbit) when playedin SS3.3 are just a high pitched grabled screatch sound.These files convertto OMA ok, but again when played in SS3.3 or the Player...grabled.The MP3 files play ok in Winamp and Media player so it has to besomething to do with this Sonicstage junk.....but whatAny IdeasThanks UBERIN Quote Link to comment Share on other sites More sharing options...
0 Guest Stuge Posted January 25, 2006 Report Share Posted January 25, 2006 Uberin,Welcome to "AtracLife"It would be better if you can restore your Windows using =>System Restore(When SonicStage was not installed )Then install Sonic Stage ver3.3 again. Quote Link to comment Share on other sites More sharing options...
0 uberin Posted January 25, 2006 Author Report Share Posted January 25, 2006 Thanks for that, but have 'Hacked' a solution.Re-encoded the 320kbit files tovariable 256min - 320max, and now they are OK!!?!! .Bit of a pain but onlyhave 125 files so not to bad (thankfully not thousands).Did find out the original problem happens on files over 128kbit.... under160 they are OK.Uberin. Quote Link to comment Share on other sites More sharing options...
0 TheReaper Posted January 27, 2006 Report Share Posted January 27, 2006 What makes you convert them to OMA? My personal opinion is that MP3 sounds much better than Atrac in most cases. Quote Link to comment Share on other sites More sharing options...
uberin
Any Ideas
Thanks UBERIN
3 answers to this question
