Charging problems with the new md player
jamie0168
I got a MZ-R900. When I plug the unit into the wall charger with the rechargeable battery inside, and press the stop/charge button, the "charging" icon flashes only once in the screen then goes away. I left it plugged it for awhile (even though nothing was on the screen,)and nothing happened. Thinking it was the battery, I got online and bought a brand new one. It did the exact same thing. The unit works with the AA battery pack, but that means that I can't plug it into my computer to transfer files. Please help me.
Is it possible you're using an AC adapter that's not right for the current where you are? A Japanese adapter may not provide enough juice in the USA.
Assuming the adapter is correct and the unit simply won't charge batteries, you could also buy a gumstick charger.
Investigate the Sony BC-7HT or Sony BC-7DT2 or Sony BC-7DC2 chargers
But the MZ-R900 doesn't have any USB computer connection. So I don't understand how you would transfer files unless you're recording out of the headphone jack, which isn't covered by the AA pack.
Edited by A440
