DSlayerZX Posted January 28, 2006 Report Share Posted January 28, 2006 (edited) I have just bought a NW-A3000, but as soon as i try it on, i realized that there are no sound at alComming from the left ear phone, can anyone help me out with my problem? appreciate itOne additional info. I already checked the help from Canada web-site, it said if it problem with Mono or Stereo headphone, the sound should come from Left, but... mine came from right.... the most funny thing is that.....THE ORGINALY HEAD PHONE CAME FROM THE SAME BOX HAVE THAT PROBLEM Edited January 28, 2006 by DSlayerZX Quote Link to comment Share on other sites More sharing options...
0 Ascariss Posted January 28, 2006 Report Share Posted January 28, 2006 Have you tried other headphones? if not perhaps the ones that came with unit are busted?also, go to the main menu, then settings, then output and check that it is set to headphone.if other headphones do this, and the output is to headphones, perhaps your unit is busted and take it back to thesony store and show them the problem.also is this with every song you have on it? even the samples? Quote Link to comment Share on other sites More sharing options...
0 DSlayerZX Posted January 28, 2006 Author Report Share Posted January 28, 2006 Ok, I found this really funny.... the earphone that came with the mp3 player does work well..... .but............the OLD earphone that came with my old MD playe worked on the unit. I have not tried Five different ear phone.Three work, two doesn't ...... and the two that doesn't work worked perfectly on the on the other player I have no idea what hte hell is going on now Quote Link to comment Share on other sites More sharing options...
DSlayerZX
Edited by DSlayerZXLink to comment
2 answers to this question
