c864fd5d Posted October 17, 2006 Report Share Posted October 17, 2006 Hello:I am going to buy a battery extender for Rh1,and find this helpful one from the threadhereDoes anybody know that how lond the battery increase compare to original charging,when recording battery is a critical factor.I also found these two from soundpro:MAC-IP-A481LEN-PPU1700BBut do not know what the differnence than the first one.Which one will you buy if you are me?But I also worry the next two ,since they do not use AA battery,therefore I concern them will be more short life time ,isn't it?Because I suppose the build in battery will die someday,isn't it?After reading the product page,I am still have no idea of the last two battery that whether their internal battery can be easily replaced or like the IRIver player that is built in ?But they add very much hours to the recording time.I want to compare these three model and choose which one is the most durable and long lasting?Thanks Quote Link to comment Share on other sites More sharing options...
raintheory Posted October 17, 2006 Report Share Posted October 17, 2006 I've been looking at some of these as well and contemplating them. However I do have one concern...When the unit is plugged into one of these via USB it actually thinks that it is running on AC power. When the unit is running on one of these it may not know when the external batteries are getting low, therefore it is feasible that you could lose your recording if the power runs out before or during a System File Writing procedure.When running on internal battery the unit will stop recording and automatically write the system file when it detects that the batteries are low in this manner, kind of a fail-safe way to be sure that there is in fact enough juice to write the system file. Quote Link to comment Share on other sites More sharing options...
c864fd5d Posted October 18, 2006 Author Report Share Posted October 18, 2006 Thanks for your reply.I am going to buy it,but do you know it does that need to buy other tip to use with Rh1?OR just order the product and the tip provided with it?(to fit the plug in Rh1?)I think gomadic is better for me,and more durable and need not to change it after several years using.(than the internal battery of the other two) Quote Link to comment Share on other sites More sharing options...
A440 Posted October 18, 2006 Report Share Posted October 18, 2006 Unless you really want interchangeable tips--which to me means a tip that's going to get lost sooner or later--this charger on Ebay works with the RH1 and appears to be the same as the Gomadic but with a permanent mini-USB tip for the Motorola Razr or RH1.http://cgi.ebay.com/New-Motorola-L6-PEBL-U...tem290038525366 Quote Link to comment Share on other sites More sharing options...
c864fd5d Posted October 18, 2006 Author Report Share Posted October 18, 2006 Thanks for your advice.I am afraid I cannot buy from ebay or gomadic,because I do not have card,and do not have friend to buy for me(we are not secure to do so).If you have other links that can pay on money order,please suggest here.Thanks. Quote Link to comment Share on other sites More sharing options...
ahsan Posted October 27, 2006 Report Share Posted October 27, 2006 I am also trying to buy the Batter extender but I have mz-nh1. Does anyone know if this product will work that unit also. Is there another compatable unit that I can buy for my MZ-NH1. Quote Link to comment Share on other sites More sharing options...
