Karmageddon Posted October 31, 2006 Report Share Posted October 31, 2006 (edited) argh!okay well for all my experiences I have avoided most of the SS hassle over the years, until now.i had to do a re-format due to a failing hard drive and backed up my files (36 GBs in about 800 Albums) using the methods listed here on teh forums, to a tee. have them on my Lacie USB drive. I re-installed all my software and re-upped s.s. 3.4 (from my MZ-RH1)and I am able to rip and encode new material and transfer to my rh1 & nh600d...however -I can not re-uplaod the database from the USB drive using the Backup Library option. It tries to authenticate it online and tells me it fails verification and closes.So I re-imported the folders one at a time (only about 20 to test) and they all play fine. the titling is still there. no issues. until i tried to transfer them. I get an an error saying "Unable to transfer tracks"is there anyone out there witha quick suggestion? I know this has come up millions of times, and have searched the forums and tried other ways of doing things. no luck. thanks in advance Edited October 31, 2006 by karmageddon Quote Link to comment Share on other sites More sharing options...
Karmageddon Posted October 31, 2006 Author Report Share Posted October 31, 2006 well just an update for those who are in the same situation as me...I have been able to get it to work, by remvoing the 20 or so albums and re-importing them. i guess something was amiss, but it is working now....for now.... Quote Link to comment Share on other sites More sharing options...
Karmageddon Posted November 3, 2006 Author Report Share Posted November 3, 2006 (edited) BUMPI thought I had this solved, but yet SS beats me again!I tried to recently transfer some of the same albums that had no problems 2 days ago, earlier today. I got an error saying tracks that are not atrac format or purchased from the connect store can not be transferred, or something to that effect.it is weird. cos if i delete the album and re-import it (as a folder) i can play it, transfer it, convert to wav, no restrictions. but every now and then when i re-open ss it won't let me do anything excpet play it. and if i check the properties for that song, it tells me i can't transfer it.what could be wrong here? this is a fresh install of xp and ss, and i never had this problem ever... Edited November 3, 2006 by karmageddon Quote Link to comment Share on other sites More sharing options...
Karmageddon Posted November 5, 2006 Author Report Share Posted November 5, 2006 (edited) bum againwell now i ahve re-installed ss according to the foumn's guidelines and used the MDAC tool and what not. still no luck. now when ever i try and convert a track to ANY format from WAV, i get a warning stating that the files contain SDMI content and that OpenMG needs to ve updated and to visit their website.WTF? never seen that ONE before...any one? Edited November 5, 2006 by karmageddon Quote Link to comment Share on other sites More sharing options...
Karmageddon Posted November 5, 2006 Author Report Share Posted November 5, 2006 so i guess since no one has had any answer for me in almost a week, that i guess i should just wipe my hard drive, yet again ,and reformat...correct?I would have assumed someone here would have been able to help....I haven't been able to access my library or do any transfers in a week.....ARGH! Quote Link to comment Share on other sites More sharing options...
