jolieuke Posted November 2, 2006 Report Share Posted November 2, 2006 Hello! Just got a MZ-RH1 two days ago. I'm learning how works all the features but since, one thing bother me a lot, the light on the display turn off so soon, something like 3 seconds. I can't figure how to change it. I tough it was on QuickMode but it's not... Do tou have some tricks, tips, bloup, bleep, ...?Thank you! Quote Link to comment Share on other sites More sharing options...
raintheory Posted November 2, 2006 Report Share Posted November 2, 2006 (edited) Menu > Option > EL Light... change it to "On". Edited November 2, 2006 by raintheory Quote Link to comment Share on other sites More sharing options...
jolieuke Posted November 3, 2006 Author Report Share Posted November 3, 2006 (edited) Menu > Option > EL Light... change it to "On".It's already On Edited November 3, 2006 by jolieuke Quote Link to comment Share on other sites More sharing options...
bobt Posted November 3, 2006 Report Share Posted November 3, 2006 Is your battery fully charged?Good luck,Bob Quote Link to comment Share on other sites More sharing options...
jolieuke Posted November 3, 2006 Author Report Share Posted November 3, 2006 Is your battery fully charged?Good luck,BobYup! Quote Link to comment Share on other sites More sharing options...
raintheory Posted November 3, 2006 Report Share Posted November 3, 2006 This is quite odd..When you say it turns off... Does it turn off completely or just dim?Also, is the battery level meter visible when the display goes off? Quote Link to comment Share on other sites More sharing options...
jolieuke Posted November 3, 2006 Author Report Share Posted November 3, 2006 This is quite odd..When you say it turns off... Does it turn off completely or just dim?Also, is the battery level meter visible when the display goes off?When both EL Light and QuickMode are ON, it's dim.When the MD is off or dim the battery meter is not visible. Quote Link to comment Share on other sites More sharing options...
Sparda Posted November 26, 2006 Report Share Posted November 26, 2006 how about you try turning quickmode off and keep el light to on? the battery meter should be visible at all times. Quote Link to comment Share on other sites More sharing options...
