Phil M Posted November 5, 2006 Report Share Posted November 5, 2006 Hi. Hoping someone might have encounterd this error message and know how to fix it.The manual suggests disconnecting the usb this however has not worked.I cannot record audio.Very frustrating.Thanks Quote Link to comment Share on other sites More sharing options...
ATELETRONICS Posted November 6, 2006 Report Share Posted November 6, 2006 Hi. Hoping someone might have encounterd this error message and know how to fix it.The manual suggests disconnecting the usb this however has not worked.I cannot record audio.Very frustrating.Thankssee if the unit is set to digital input for the source. i am assuming you should have it set to analog if you are using the analog input? my deck works like that. Quote Link to comment Share on other sites More sharing options...
