Import AAC (.m4a)? - SS 4.0 Problems
Paula
Aren't I supposed to be able to import AAC (m4a) into SS 4.0? Says so in the "help" anyway... I just get an error message giving various reasons why the import isn't working (incompatible file type, file can't be found, unusual characters in file name...) It's an itunes podcast, and is within the required bit rate...
You know I just checked again - it DOESN'T say "protected." I must have looked at the wrong file the first time, because some of them DO say "protected." But these don't. So why can't I import? (I get the error msg that it "does not support this file format.") Yet if I first use iTunes to convert to mp3, it will import fine.
Edited by Paula
