TheOneill Posted December 8, 2006 Report Share Posted December 8, 2006 Hello,I'm planning to buy an RH1 before it becomes too hard to find in France (it has alaready disappeared from mais stores). I had an R30, R55, R900 and NH900 and all of these units (except the 55) had a great feature in my opinion : the possibility of searching for a song browsing them on the screen without stopping playback. The NH900 had an even better function : you could search the title you want to play through an alphabetically sorted list (using usefull->search). I know that this funtion disappeared on the rh1 but I'd like to now if at least it's possible to jump from a song to another one without pressing prev or next repeatedly, stopping the playback of the current song.Thanks a lot ! Lionel Quote Link to comment Share on other sites More sharing options...
raintheory Posted December 9, 2006 Report Share Posted December 9, 2006 Im not positive, but I believe you will only be able to accomplish this using the RM-MC40ELK remote.I'll double check this later to be sure, or if anyone else can check, go for it. Quote Link to comment Share on other sites More sharing options...
TheOneill Posted December 9, 2006 Author Report Share Posted December 9, 2006 You can browse through the tracks with the 35ELK too, by searching by group, artist, album, or title. The 40ELK is more comfortable to use.Oh ok! yes it's line by line browsing but it's not so bad.Thanks for your answers ! Quote Link to comment Share on other sites More sharing options...
TheOneill Posted December 9, 2006 Author Report Share Posted December 9, 2006 Just a little precision : how do you search by artist for instance with the 35ELK? I've got it with my NH900 and can't find the way to do that. Neither is it mentionned in the RH1 manual.Thanks,Lionel Quote Link to comment Share on other sites More sharing options...
