phil91 Posted December 16, 2006 Report Share Posted December 16, 2006 (edited) is there a way to download the older sonic stage 3.2 version or 3.3 or 3.4 ?with the new 4.2. the software doesn't recognize the cd-drive on my pc Edited December 21, 2006 by Ishiyoshi Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted December 16, 2006 Report Share Posted December 16, 2006 Welcome to MDCF!To resolve the problem, you may need to re-install the latest PxEengine version for SonicStage. To download the latest version of PxEngine, please click here. (*PxEngine is basically a writing engine which relay tasks between a given software and your CD/DVD writer) A forum member, A440 has made MDCF's SonicStage 3.4 Full Installer available: here.Good luck and report back if the problem still persists. Quote Link to comment Share on other sites More sharing options...
phil91 Posted December 18, 2006 Author Report Share Posted December 18, 2006 Welcome to MDCF!To resolve the problem, you may need to re-install the latest PxEengine version for SonicStage. To download the latest version of PxEngine, please click here. (*PxEngine is basically a writing engine which relay tasks between a given software and your CD/DVD writer) A forum member, A440 has made MDCF's SonicStage 3.4 Full Installer available: here.Good luck and report back if the problem still persists.thanks a lot !!! problem solved Quote Link to comment Share on other sites More sharing options...
Ishiyoshi Posted December 21, 2006 Report Share Posted December 21, 2006 You're most welcome; glad the problem has been resolved. Do enjoy your stay with us. Quote Link to comment Share on other sites More sharing options...
HauseMan Posted December 28, 2007 Report Share Posted December 28, 2007 (edited) I just downloaded both the older v3.4 (if only to have it around) and the Px fix. Hopefully that'll solve MY issue of SS 4.3 suddenly not recognizing my burner. I'll be sure to recommend the fix to friends if and when they start having issues with SS 4.3Paul Edited December 28, 2007 by HauseMan Quote Link to comment Share on other sites More sharing options...
Syrius Posted December 29, 2007 Report Share Posted December 29, 2007 (edited) Hey, anyone know where can I get 3.4 full installer? Edited December 29, 2007 by Syrius Quote Link to comment Share on other sites More sharing options...
HauseMan Posted December 29, 2007 Report Share Posted December 29, 2007 Hey, anyone know where can I get 3.4 full installer?Check the second post above, there is a direct link to it. I downloaded it just to have it around, in case 4.3 fails.I just downloaded both the older v3.4 (if only to have it around) and the Px fix. Hopefully that'll solve MY issue of SS 4.3 suddenly not recognizing my burner. I'll be sure to recommend the fix to friends if and when they start having issues with SS 4.3PaulYep...this solved my problem. I've just completed two ATRAC CD burns, and everything's back to "normal". Quote Link to comment Share on other sites More sharing options...
