House Posted December 20, 2006 Report Share Posted December 20, 2006 I'm fairly new to live recording. I have GreenMachine's "basic" microphones as well as his battery module. I also have some old Sharp MD recorder. It doesn't do much apart from playback and recording in Short-Play (MD-SP).I made a few recordings:Fun!Yeah! - local band in small venueDragonForce - Power metal band in reasonably large venueStiff Little Fingers - punk band in mid-size venueAll have come out with quite a bit of bass. I haven't had a chance to put SLF and DF on my PC yet so i only have Fun!Yeah! to give you an idea of what my recordings sound like.I can't really hear the bass when playing back on my PC through a pair of truly awful speakers, but when i listen with my Sennheiser HD 555s, it's all to obvious.If anyone has any suggestions to how i can reduce the bass (either during recording or afterwards on the computer..) then please do help me out Fun_Yeah____I_ll_Remap_Your_Network.mp3 Quote Link to comment Share on other sites More sharing options...
greenmachine Posted December 22, 2006 Report Share Posted December 22, 2006 Virtually any software based audio editor has a built-in equalizer (EQ), so does the free Audacity. An example how the EQ (in the menu under effects) could be set to reduce low frequencies:[attachmentid=2156] Quote Link to comment Share on other sites More sharing options...
royalrepis Posted December 27, 2006 Report Share Posted December 27, 2006 To reduce the bass during the recording you need to use a bass roll off filter or use a different polar pattern microphone. To cut the bass after the recording then you need to do what Greenmachine suggested. Quote Link to comment Share on other sites More sharing options...
House Posted December 28, 2006 Author Report Share Posted December 28, 2006 Thanks for the input guys, i've had a quick go at adjusting the EQ and it seems to be a lot better. I'll take a good look at it later.Thanks again Quote Link to comment Share on other sites More sharing options...
