Check-In FAILED. Detected errors - Everytime!
moodi
it is a NetMD recorder which does not allow uploading (from MD -> PC)... you should look into HiMD if you want a player/recorder that can upload and the RH1 is the only existing machine for now that is able to upload the recordings you have already made with the NetMD
still there are other (realtime) options... just have a look at this thread
PS: checking in only adds one unit back to the 'limited number of transfers'-counter for tracks that were already on your PC in the first place. This counter was used some time ago by Sony to limit the number of times you could transfer a track from PC -> different MDs. It never had anything to do with transporting audio info over USB from MD -> PC (that last thing is called uploading and was only introduced with HiMD)
PS2: sorry to say this, but this is another example of lack of research before purchase (unless of course the seller lied to you... no really, even then it would still be careless not to check this, certainly when buying through ebay)
Edited by The Low Volta
