Basic Hi-MD purchase question
moodi
Ok, looks like i'll be swopping the old NetMD for a Hi-MD...
What I'm after is very simply the ability to transfer files MD > USB > PC.
What's the best all-round model? Any I should definitely avoid?
Ok - which is the better out of these for what I want?
http://www.amazon.co.uk/Sony-MZ-NH600-Silv...n/dp/B0001ZN754
http://www.amazon.co.uk/gp/product/B0007UB...0489688-1156445
cheers
moodi
Edited by moodi
If you're looking for uploading your pre-Hi-MD recordings, neither of the linked models can do it, they only upload Hi-MD mode recordings. Only the RH1 can do it. Or you go the analog/digital realtime route. (http://forums.minidisc.org/index.php?showtopic=7070)
