Connect player - skipping track when addingto library
Riofer
Hi
I'm new here so hopefully this isn't a dumb question. I have some radio shows saved in MP3 format at 64kbps. When I try to add them into connect player library a message at the bottom of the screen indicates that the tracks are being skipped. These are quite large MP£s up to 30,000kb and over an hour long in some cases. sO FAR (touch wood) I have had no other problems with connect player but I'm getting frustrated by this.
Any suggestions would be gratefully appreciated.
Cheers
Rio
2 answers to this question
Uhm, well check to see if they haven't alreayd been added to the actual library, since if it is skipping the files that may be the case.
next, it has nothing to do with file size, i've imported mp3 files that are well over 300-400megs into Connect player and transferred them over to my A3000.
