floz23 Posted April 6, 2007 Report Share Posted April 6, 2007 What line-in recording level will add no gain (0db) to the signal? Whats the standard recording level?I believe this was answered before, but I cant seem to find the post :/-Adam Quote Link to comment Share on other sites More sharing options...
Strungup Posted April 6, 2007 Report Share Posted April 6, 2007 floz23 said: What line-in recording level will add no gain (0db) to the signal? Whats the standard recording level?I believe this was answered before, but I cant seem to find the post :/-AdamHold in the "Display/Menu" button till you get to menu , scroll to Rec Settings, select AGC , if your signal does not go above a certain point then the AGC wont kik in, there are two types of AGC one for Music , and a Standard , try them both see what you like . If that doesnt work for you then use the Manual Rec settings, and just set the Rec level to a likable point where your not peaking (-2 is good ) Optical connection use AGC works very differently you also have Manual Rec on the Optical connection.I have used it frequently. Quote Link to comment Share on other sites More sharing options...
floz23 Posted April 6, 2007 Author Report Share Posted April 6, 2007 Guitarfxr said: Hold in the "Display/Menu" button till you get to menu , scroll to Rec Settings, select AGC , if your signal does not go above a certain point then the AGC wont kik in, there are two types of AGC one for Music , and a Standard , try them both see what you like . If that doesnt work for you then use the Manual Rec settings, and just set the Rec level to a likable point where your not peaking (-2 is good ) Optical connection use AGC works very differently you also have Manual Rec on the Optical connection.I have used it frequently.There is no -2 setting on the recorder, the manual recording setting goes from 0-30-Adam Quote Link to comment Share on other sites More sharing options...
A440 Posted April 6, 2007 Report Share Posted April 6, 2007 (edited) Unity gain--same level as the incoming signal--is around 17/30 or 18/30.That won't really help you in a live music recording situation because mics vary in sensitivity, music varies in loudness, etc. I don't even know that it helps much if you're recording from a line-level input because you can change the volume output from a CD player or a miixer. What guitarfxr is suggesting is to look at the level meter and see that it's peaking just a little below the top. Edited April 6, 2007 by A440 Quote Link to comment Share on other sites More sharing options...
