Track Names
m_fergy
I have got my MZ-RH1 connected to my mixer through a digital output and I thought it would automatically put the records names on the mini-disc when I am recording
Do I have to enable a setting for this to happen ?
Thanks
Your records are analouge , and carry no text info , plus the LPs are connected analouge to the mixer then the mixer converts to Digital . The only way you get text, is if you are using a CD Player that has Text Transfer capability . Then and Only then will you get Track names automatically.
CD -MD direct , no mixer
Ok thanks alot :D
Edited by m_fergy
