marquette5 Posted April 18, 2007 Report Share Posted April 18, 2007 I just got my MZ-RH1. I'd like to erase my 1 gig disc which is already full but I can't find anything in the manual that makes sense. Do I need to use the remote? Thanks for your time. Quote Link to comment Share on other sites More sharing options...
A440 Posted April 18, 2007 Report Share Posted April 18, 2007 Hold down the Menu button. You will see Menu [Rec Settings]Use the jog lever (on right) to go from Rec Settings to Option to Edit.Push in the lever and you'll have choices for Edit--go to Erase.You can take it from there. Quote Link to comment Share on other sites More sharing options...
marquette5 Posted April 18, 2007 Author Report Share Posted April 18, 2007 Thank you, I'll give it a try.Hold down the Menu button. You will see Menu [Rec Settings]Use the jog lever (on right) to go from Rec Settings to Option to Edit.Push in the lever and you'll have choices for Edit--go to Erase.You can take it from there. Quote Link to comment Share on other sites More sharing options...
KJ_Palmer Posted April 18, 2007 Report Share Posted April 18, 2007 You can also use the Sonicstage software to erase the whole disk or tracks, whilst the RH1 is connected. This might be somewhat easier than using the fiddly buttons on the unit itself. Just go to Control-Device/Media-Initialise or highlight the tracks and hit Delete. Quote Link to comment Share on other sites More sharing options...
Sparda Posted April 20, 2007 Report Share Posted April 20, 2007 Also make sure that the tab is in the write/unlocked position Quote Link to comment Share on other sites More sharing options...
