Help Hi-MD to Mac transfer
Carlos.Santiago28
Please Help!
I've got a MZ-M10, with the Music Transfer 2.0 software, and I can't get any recordings (from the included mic in PCM, SP, or LP mode) to upload. I just get the gray quarter note.
Sony says it's my fault, but I can't for the life of me figure out what's wrong.
I've sat with an identical recorder, identical settings, and done everything the same. The other recorder uploads fine. When I switch the discs out, my recorder uploads what was recorded on the other recorder, but NOTHING recorded on my recorder will upload to any computer. Same thing when tried on a different computer.
I'm running Tiger on a PowerBook G4, 1.5 Ghz, with a gig of RAM.
I've sent the unit to Sony 3 Times, and they say nothing's wrong (and yelled at me, to boot).
Please help. I'm looking at a $300 paperweight.
Please Help!
http://bssc.sel.sony.com/BroadcastandBusin...acv20manual.pdf
Check to see if your machine is in HiMd mode or standard MD mode first.(Menu-Option-Disc Mode)
there is the manual on The program. One thing is that you have to make sure to format the MD in HiMD mode before you record, otherwise it wont transfer.
You can use Regular 80 min and 74 min discs bu you need to format them to HiMD , then record in HiMd mode , they should upload then.
Edited by Guitarfxr
