MZ-NH1 Box Contents
noadankes
Hi, i have bought a second hand NetMD NH1. Can anyone who has one give me the exact box contents so that i know everything is there?
Mainly i am intersted if there are two USB cables or one? I have the cradle and a USB cable for that but i don't have a USB cable that goes directly in the player - should there be one on UK bought models?
Thanks
Do you have the N1 or the NH1? The NH1 has a special USB cable that goes to the deck, there is nowhere on the charging stand for the cable. Usually what comes standard with the units are the deck,headphones, a Sonicstage disc, a USB cable, an optical cable and a minidisc.
HTH
Bob
what you should have should be listed in the manual:
http://www.css.ap.sony.com/consumer/templa...=Personal+Audio
Select Hi-MD walkman in the first drop-down.
As far as I remember, only the Japanese versions come with a long and short USB cable.
(at least that's what I heard a while ago)
Edited by tekdroid
