Mono or Stereo Plug for Minidisc R55?
Mike Rophone
Hi, all! Many thanks for all your microphone info. It's been a real help!
May I ask another quick questions. Am connecting a mono mike to a Sony R55 Minidisc. I can get a wire with miniplug, but it's mono. Should I use a stereo plug into the Minidsic, even though it's a mono mike, or will a mono plug work okay in the minidisc?
Best wishes,
Johnny, Manchester, England
Best wishes,
It should work just fine. Be sure to set the recorder to MONO, otherwise you risk only hearing the signal through the left speaker on playback.
With a mono plug you will get a signal in the left channel only. If you record in stereo mode, you will record the signal in the left channel only. If you use the mono recording mode, you will get lower than desired levels because the left channel signal and the right channel silence are mixed together and the average is recorded. If you have a mono to stereo adapter, use it.
